Hi…I moved to a new location and was very busy so I couldn´t use my roon and uniti atom combination. Today I tried to set it up but the atom does not show up anymore in roon and i did not find a way to add it. Was something changed concerning the roon availibility?
You might need to enable the Atom in the “Audio” section of the Roon settings menu?
It´s not showing up in the audio section
Hmmm, are your Roon server and Atom on the same network?
yes…both connected via cable with my UDM same subnet
Assuming that’s a Ubiquiti Dream Machine I have nearly the same arrangement here (regular Atom on Wi-Fi and not HE) and - unhelpfully for you - it’s working fine. My Atom had a bit of a tantrum a couple of weeks back so I did a factory reset and set it up again, I guess that’s an option otherwise I’m out of ideas
Thanks…maybe that´s the best option will try that!
@swoti
Are you using a Mac and getting the ‘No audio devices found’ message? If so I may have a solution for you.
Restart your roonserver
The following was posted by someone on the Roon forum and works for me (on Mac’s only):
“The issue with Sequoia allowing access to local network devices by third party applications is typically caused by a reboot.
You need to go to settings/privacy&security/local network and toggle the Roon entries off then back on. Then quit Roon server by clicking on the menu bar item and choose quit, then once Roon server has closed, reopen the Roon app. This forces Roon to rescan the network for devices. Your devices should then reappear (do for me every time)
Do not reboot your Mac after toggling Roon off and on in local network as the issue most commonly occurs after a reboot so the toggle is voided”.
