Uniti Atom HE + PMC 25 active
Hi. I recently bought a Uniti Atom HE and I want to use it as a streamer-preamp; I also have a pair of PMC Twenty5 22i that I can upgrade with the active kit; has anyone tried the Atom with active PMC?
Thanks.
Try looking through the Active PMC vs ATC thread.
Roger
Also here (23 instead of 22)
A number of members have done this, with good results. @HungryHalibut has recently upgraded to this.
DG…
Hi @Supergiangio, as @robert_h said, I’ve got my Atom HE paired with active PMC Twenty5 23i’s and couldn’t be happier with the setup. I would say the active 22’s would be a perfect match for your Atom HE.
When I got my 23’s the plan had been to get the 22’s myself but I got a great deal on the 23’s - ex-demo - and after hearing them at the dealers I didn’t bother listening to anything else, including the 22’s.
As an update to the story @robert_h referred to, the guy from the dealers with the NSC 222 did end up swapping his NAP250 for active boards for his 23i’s.
I have the twenty5.21i active with an Atom HE and it’s fabulous. The active upgrade is brilliant value and really can be fitted in five minutes. You won’t be disappointed. Get some Mogami XLR leads and off you go.
Your positive feedback have been really encouraging! Thanks a lot to everyone.
Hi HH,
Do you believe your ‘posh’ remote handset would support the NC Series, specifically the NCS 222?
ATB, J
It’s an ND555 remote. Armed with that information, I’d suggest you ask Naim Support. I have no idea. I think they cost something potty like £800 to buy.
Thanks HH,
Always worth keeping an eye out on the s/h market :wink:
ATB, J
I’ve found the way to home demo the upgrading active kit on my twenty.22.i. Early impressions are not so good:
Positive: more dynamic and bigger soundstage.
Negative: the sound seems to be more “asciutto” in my language (italian)…I think the world in english could be lean.
Do you think it may need some running-in?
I changed from a 300DR driving twenty5.23i to the active modules and ‘lean’ is the last word I’d use.
Can’t speak for the Atom HE as source/pre mind.
I think it unlikely the amp will change much.
Sorry, I’ve made a mistake in positioning the connector in the amplifier; put it in the second slot that is the one for twenty.22 and I have 22i. Now I have moved it in the right slot and the sound has changed radically and gained weight.
Thanks for all the replies.
I thought you’d perhaps done that, but I didn’t like to say!
Glad you’ve sorted it. Enjoy.
I also have the HE with active 21I’s and it sounds fabulous.
