Hi,
I have problem with my Uniti Atom screen. Every time when I turn on my Uniti Atom my screen is blank and I can’t move anywhere from there. If I want to use it again I have to disconnect it from power source and reset it. After all these things screen starts to work properly. Any ideas how I could fix it.
Hard reset.
Hard reset, had same in my Star yesterday.
Ps its likely to return once youve had it…
Are you on the latest firmware update? I had a similar issue where the screen was frozen or blank but it hasn’t happened since the last update and looks to be fixed properly. How often does this happen? PS you don’t need to unplug the power, you can do a hard reset by holding the power button for around 10 seconds.
Mine required full power off to clear it. Latest firmeare downloaded on release day.
I have the same issue but its random and not often.
Also sometimes the volume display value doesn’t show or is delayed
Firmware up to date
