Hi all .
I have an original uniti atom and I see a Focal dome subwoofer for sale.
Are they connectable . Uniti has two plugs red and white.subwoofer has one etc
In theory they could be connected using the high level input. However, it looks like the Dome sub is really designed to work best as a set with the matching satellite speakers. Also, it’s not so easy to connect both the sub and speakers to the Atom via its 4mm sockets - and not even recommendable that way either as it can sometimes cause upset to the amp and poor performance. With Naim it’s usually better to connect the high level from the terminals at the back of the main L+R speakers, which usually means custom cabling at the very least.
Thanks for the reply
The last thing I’m doing is upsetting my atom.
So I will stay with my acoustic research sub.
