Uniti Core disappeared from Win 11 PC
Thankyou, I waited patiently for such a simple solution.
I spent many wasted hours in a previous life being a pseudo Windows fixer with regedit, usually breaking Windows. So I didn’t want to repeat my mistakes.
The above MS link fixed the Naim Core access via Windows 11 Pro, in 30secs
Sadly this doesn’t appear to be an option in windows 11 home edition. Thanks though for reporting your solution. Let’s hope Naim comes up with a workable solution to this.
The Core appears in my network in file explorer, I click it open and get an error message saying 192… is unsecure. I can’t get further. I have no such problems when using my mac. All are working on the same home network.
Some people must surely be using a windows 11 home edition pc to transfer music to/from the core.
Even if the Core “works” with SMB2 or 3, did you check if the SMB1 is enabled ?
The Core doesn’t use SMB1, so there is no reason to enable it.
The error message is from Windows, not the Core…
It costs nothing to check and try !
I have Windows 11 Home, SMB1 is enabled and I have access to my Core…
