Is it possible to change the Composer in the metadata as I notice that some albums include that information but I don’t seem to be able to change it.
The Core allows you to change metadata for album and artists names. In the Naim app select the album you want, click on the 3 dots in the top right corner, then select “edit metadata”. For classical music I’d change the album content title to start with the composer’s last name. Then don’t forget to click on “save” in the top right corner.
Bob’s workaround is OK so far as it goes, but no you can’t edit the composer such that the composer search can be usefully used. Naim have in the past said that this was something they would change later, but we’ve been asking for it for a long time…
Best
Thanks for that. I suspected as much but thought I should confirm.
