Input Trim Settings: Factory Reset is; 0
What are the average Input Trim settings for each Input?
I am not sure there are “average” settings for Trim as it will depend on each devices output into the Uniti. I think you will need to adjust them by ear, well that it what I did, to get a consistent volume across inputs.
Thank you Paul for that advice on trim settings.
