I have a system which uses a Unitilite to power Lin Kans. The TV fits via a toslink which is a poor fit at the Naim end. It’s annoying in a high quality product but I digress. I am thinking of buying an Atom. It has the advantage of Qobuz compatibility whereas the Lite does Tidal or Spotify. I have a Qobuz sublime subscription. I would welcome the forum’s advice as to whether an Atom would be an improvement
You may find a different optical cable would fit better.
