Uniti Nova and Amazon Zigbee support
Hello
Has anyone tried controlling their Uniti Atom/Nova with the Amazon echo plus using the built in support for Zigbee?
Just curious
Suneal
Hi, I believe the Uniti’s do not support Zigbee. With my iPhone I can use it as an airplay device and therefore control it as I stream directly from the iPhone, but it’s not controllable through the HomeKit app As a smart device. If I understand you correctly.
Michael
The Unitis do support Zigbee as it’s what their remote control uses, but I assume that’s their own implementation of it, so I have no idea if it can be used to communicate with any third party device.
Thanks I thought it was worth researching. I was hoping the newish Amazon Echo plus with its Zigbee hub support might work.
