Uniti Nova & Core issue
I’m looking for help on a Nova/Core setup. My Uniti Core was working fine with my Nova until recently when firmware updates were downloaded to both devices.
Now the Uniti core cannot be seen on the Naim app and the Nova cannot connect to it or play anything from it. Adding a new device from the app results in a time out with “no device found” when selecting Uniti Core.
Nova still functions correctly on iRadio and streaming via Spotify. Core is hardwired to router and Nova connects via WiFi.
Any advice for a fix gratefully received. If all else fails is a factory reset on the Core the way to go?
Is the Core getting an IP address from your router? I would start by restarting the router and Core.
Yeah. Restarted the router and the Core but no joy​:frowning:
Not sure about the IP address so might have to dive into the router settings? Wish me luck :man_facepalming:t2:
Playing music shouldn’t have to be this hard eh?:man_shrugging:
Did you sort this out?
If not, are you talking about the IOS app or the Android app? Also if you can’t see the Core in the app, can the Nova see it (ie if you tap servers on the Nova home page, does it show the Core there?)
Has there really been a recent firmware update for the Core?
I haven’t seen any notification - mine is on 2.5.8 (4069).
That is the current version. It’s not a recent release though, but maybe the OP only recently did it.
Maybe, but that version is quite old now as far as I can remember. Anyhow, I hope the OP is no longer here as they were able to get the Core and Nova talking to each other again.
Yes I think (from looking in the beta group) that this version was released in August 2025.
No it’s still not solved but I’ll keep trying.
Ok so what are the answers to my questions? I’ll try to help.
Have you tried to restart your router and install the app again?
