I recently unplugged my Nova to place some IsoAcoustics footers underneath and it appears I’ve broken it. Current boot sequence looks like this
- Plug in the power cable
- Hear the “click”
- Naim logo appears with progress bar on the bottom
- Home screen appears with “Now playing”, “Spotify”, etc. buttons. Network indicator icon is there.
- Power button is blinking with 4 flashes, a pause, 1 flash, a pause, and 3 flashes. (4-1-3 error code?)
At this point the unit is not responsive. The remote doesn’t work, the on-unit buttons don’t work. The nova appears as a room in the Naim app, but trying to select it just returns an Unresponsive error.
Tried to do a factory reset, but it doesn’t appear to do anything. Also I’m a bit confused about the “powering” on step. Should I be holding the Play/Pause and Input buttons, and then attaching the power cable? Or while pressing the power button? Neither seems to do anything.
Any ideas?
