I’ve reset my Uniti quote to factory settings and it’s no longer working with the remote. I can still use the app to control the quote in rooms.
Does anyone know how to pair the remote? I seem to recall that there is a button sequence required to do this but can’t find reference to it anywhere.
Thanks in anticipation of your help.
Don
What you do is restart the UnitiQute and while you see the splashcreen startup on the display press these three buttons on the remote simultaneously - aux, i, and disp.
Perfect! Thanks for the help.
