Uniti Serve
Just picked up Ebay Uniti Serve.
Looking for the disc that came with it originally
Fred
Drop Naim an email, they can send you a link to the most recent version of the Serve’s software.
If you are referring to the firmware update disc, which version is it running now? It should be on 1.7c but if it isn’t on the previous version 1.7b you’ll need to install that first. Naim support can usually supply the discs.
