How can I get rid of the Spotify icon on the screen and add a Tidal one there?
Settings/Input Settings - then Spotify and Tidal to enable or disable
Also Settings/Sources Layout to move the order they display
You can’t add or remove these inputs from the front screen, but neither can you control them from there either. You would use the app on a portable device, so the screen is of no relevance really.
