I have a Uniti Star.Will it run a 4tb external drive if I divide the content into 4 x 1tb folders? Spec says it only supports 1tb.
I think the answer is no. It doesn’t matter whether you have one folder or 1000 folders, it’s the total size that matters.
Best
Ok, thanks.
Didn’t want to waste money.
With a library of that size I think you will find a regular NAS running a UPnP server a better option.
