I brought a uniti star and a stage line with I supply to power it.
The old star had one interconnect that powered the unit.
My old Snaic cable won’t connect the phono stage to the star which I find odd as it’s 5 pin. And it looks like the audio out on the Stageline is 4 pin.
So what exact cable should I buy to
Fit between the Stageline and the star as mines obviously incorrect
I’m not an expert, but to my knowledge, the new Unitis (Atom, Star, Nova) don’t have the capability to power any other devices (including phono stages).
You’ll need a 4 pin to 5 pin Naim interconnect, rather than a Snaic, to link the Stageline to your Star. You’ll also need a power supply to power the Stageline, so a flatcap or Hicap. You may also wish to consider getting a self powered phono stage, depending on which cartridge you use.
