I’ve connected my TV to my Star via optical cable and hear a fluttering sound. I checked the connections and they’re fully intact on both ends.
Bad cable?
Bad cable?
Make sure you have changed the sound setting on the TV to PCM, then should be fine.
Yep, Mikes put his finger on what could be the issue. I had the same problem which drove me mad for about an hour or so before I realised what was the problem.
