Uniti Star remote - works for a very short time
Tried to use my remote for the first time in a while, and I can’t get it to (re-?)pair properly. If I take the batteries out and then put back in, the remote works as expected until I pause and the display goes to sleep; thereafter it never wakes the display up or controls the main unit.
Rinse and repeat & the same thing happens again. How do I make it work for longer periods?
TIA
Sounds to me like the batteries are running low. These new Zigbee remotes chew them much faster than the old IR ones.
There is a FAQ on how to pair naughty remotes. Also, possibly your Star needs a full reboot, as in switch it off and unplug it, wait, and start it up again.
I had a similar problem with my Atom remote. Changed batteries - all good…
Only got 6 months out of the batteries - seems short to me. Earlier poster mentioned the same thing
I’ve not had to change mine for 2 years as yet. Though I must say I use the app a lot as well.
