Anyone having any issues with their volume wheels? Mine used to work and now does not. I’ve unplugged, I’ve done a factory reset, no luck. Everything else works fine on the unit. I can control volume with the app and remote control. Help?
You should speak to your dealer, as it seems the unit is broken.
