Uniti Star Vs Uniti Nova
Perhaps good to add I compared with B&W 702s2 (which I ended up getting), Revel F206 & Sonus Faber Sonetto V.
Thanks for that. I think for me it would be the Nova of the two. However, it’s beginning to feel like a more likely upgrade for the future would be the Atom HE and some active speakers (some obvious favourites on here, and a few good options that I’d no doubt need to consider).
Started with the Star in oktober and now playing with a Nova. I’d say, go Nova all day unless you want to use active speakers, than Atom HE is the thing for you.
Yes, see above (thanks).
