I have a Uniti which has been working fine for years. Today it continued to receive a signal on Digital 2 but wouldnt play any sound - using the buttons on the front i see that the prev button performs the next function and next does nothing. I think its lost its config. How do i do a factory reset?
One of my Unitiqutes stopped working this week. I was installing a new switch when it went down. I had to turn it off at the mains, let it cool down before restarting. That solved my problem, but yours might be a different issue.
Tried both a) leaving it and b) factory reset of settings. Still no sound coming out of it. Have tried both signal in on Digital 2 and playing through the CD. Any other thoughts?
Do you get no sound from any input? Assuming you haven’t accidentally hit the Mute button, that might indicate a fault with the unit, although that wouldn’t explain the prev/next button issue.
Naim Uniti running Version 2.0.00
Inputs tried:-
Digital 2,4 using an optical cable from PC - can see signal leaving PC on the right output - can see it arriving in the uniti as when I stop playing it from the PC the input on the Uniti shows no signal when i start it again - shows signal
CD
Mute button - tried on and off and i can see it working ok - no impact to sound
Buttons on the unit are working - was expecting the next/prev to navigate the list - but they dont - the remote control directional arrows controls that part ok.
Uniti wired to a single pair of speakers.
Also not getting anything out of the headphone socket either. But i do still get the electrical click when changing between headphone and not.
If that’s the firmware, it’s a very early version. Possibly worth updating it, but you should contact Naim support before attempting this from such an early version. I’m beginning to suspect that this may be a fault that needs to be looked at by Naim, so may require a return to the factory.
