I just tested mine and it’s buttery smooth with no wiggle. Too bad I don’t have a reason to use more often but sit at a distance, so using the remote or volume in roon instead.
@Naim.Marketing I would really appreciate your take on this. The device and volume control is working perfectly fine so if it is just cosmetic and not indication of a manufacturing fault I am happy to live with it.
Spookily enough, the production quality team had just got back to me as I saw your message pop up. They said thanks for the video, which made it clear. All within range and nothing to worry about.
