Unitilite vs Nova Upgrade minimal Improvement
I’ve just “upgraded “ my Unitilite to a Nova and am somewhat underwhelmed.
I have also upgraded the speakers from my 25 year old JBL xti20 to neat mystique and whilst different, the JBL are bassier and perhaps slightly less detailed but have a lovely sound and handle vocals equally well as the neats.
I just don’t feel like I have £6000 worth of audio improvements!
Using lossless Apple Music via iPad digital cable to usb to spiff converter into coax input on unitilite.
Any suggestions on what I’m missing? A hearing aid?
Never heard any of mentioned speakers, but why to expect that Nova will be better than Unitilite?
The new speakers may not yet be run in so it could be too early to judge. And speakers are a very personal thing so maybe they are not to your taste or do not suit your room? Have you tried your old speakers on the Nova? I run 45 year old B&W DM4 speakers on my Nova and they sound excellent.
With the Nova you get a more modern platform with greater (or easier) streaming capabilities but I have never heard a Unitilite so can’t offer any thoughts about comparative sounds.
Although it is more expense, a Powerline is a good upgrade for the Nova in mine and many others view (suggest second hand).
More power, better newer components, large toroidal transformer, multiple reviews telling me it’s better.
Good point, however, as listening is key. I wanted the native streaming support which the unitilite no longer has.
Running in the speakers might be the factor.
I did get the old speakers surrounds replaced last year so they still sound good.
Certainly the improved streaming support was my main reason for the upgrade.
Thank you for your suggestions. I’ll be patient before looking for another upgrade.
Good point. Apart of marketing we have to remember that perception is different, thus newer and “more powerful” is not always better.
You do need to be careful to ensure that a new system isn’t just disappointing because it sounds different and you’re not used to it, rather than because it’s actually worse.
Are your speakers brand new, or have they been stored unused for a while? They may well need a couple of weeks of regular use to break in before they sound right. Leave them playing as much as possible if you want to speed up this process.
Have you tried to experiment with speaker positioning, especially changing the distance from rear and side walls? This can be critical in getting any speaker to sound right. Also check that they are connected correctly. L and R sockets are the other way round on the Nova compared to the Unitilite, but more importantly, double check that they are not connected out of phase, which will result in reduced bass output.
Maybe experiment with some different music sources. Did the SPDIF converter sound better on the UL than using iPad into the USB input? Are you using SPDIF on the Nova too? Try lossless 24 bit Tidal or Qobuz or some music files on a NAS/server or a USB drive to get the best from the Nova.
Good luck!
One could think, why did you buy it then ?
Didn’t you get a dealer demo first ?
Did you take care of good cables, plugs and mains, in order to optimize setup ?
Anyway, the loudspeakers are way different than old JBL.
If my Neat Petite classic are anything to go by, they sound great out of the box but are definitely a slow burner and require extensive running in. Personally took me a year to get there, to what I consider magical speakers now.
Speakers are a very personal taste, one person’s wonderful may be unlistenable for someone else. I’m guessing you didn’t her them before buying, which is always advisable if not always possible. When not possible a lot of research is needed, including reading multiple reviews by people whose views you know you can relate to. Can you return them?
On the Nova side, is it said to be an upgrade, or just the modern version with updated digital end?
If the speakers are brand new, running in as others have suggested may improve the bass a little, but unlikely to be a mammoth difference and not needing more than 50 hours or so of play at sufficiently high volume to get the bass cone moving visibly. If ou are very underwhelmed cables are unlikely to raise things hugely, being more fine tuning than system changing.
Perhaps audition the Nova PE……..? I heard briefly it whilst evaluating the Selekt DSM variants and commented at the time that had I just walked in off the street for a try-before-buy comparison, it would have been my first choice in a heartbeat.
Just a thought.
ATB, J
My Nova was purchased new just over 7 years ago & I remain very pleased with it.
If yours is brand new I found that mine was underwhelming for the first 5 or 6 weeks of use (2 to 3 hours use a day), then it drastically changed for the better virtually overnight.
Then there was another, far more subtle, change for the good at 9 months old. Since then it has not changed at all & the only blip was the October 2024 infamous 3.10 firmware (which affected numerous other Naim products).
Your Nova should be on firmware 3.13, which has no issues & is considered extremely good by virtually everyone.
I’d be surprised if you don’t come to enjoy what the Nova offers.
