Can I get Qobuz update for a Unitilite? Can I use A unitilite as multiform without another Naim streamer?
No.
No. Although I don’t quite know what you wish to do here.
There are workarounds involving other kit for both but you would need to give us more information.
Best
I used mconnect app on my iPhone to get Qobuz to my lite
Did you mean multiroom?
The short answer is no, The 1st generation Naim streamers will not support Qobuz, and multiroom playback is a proprietary thing that only works with streamers of the same brand.
If you’re up for a bit of tinkering, there are various workarounds that could give you both of these options.
