UnitiQute 1 hiccups on specific MP3 files
I recently upgraded my old UnitiQute 1 to the latest firmware (now on 4.9.40).
It now emits two behaviours I had never seen previously.
I have MP3 files on a USB stick and when using the “iPod” input they play directly through the Qute’s codecs very well.
Last week, three out of 88 of the MP3 files performed a hiccup after approximately 4.7 seconds, before restarting from the beginning of the file and playing it correctly from beginning to end.
To put it another way, for (only) these files, the first 4.7 seconds plays twice consecutively.
It is entirely reproducible with these files.
The files play fine from my laptop and VLC (and other media players).
As a test, I transcoded the files into OGG (using Audacity) and the UnitiQuite played them normally from beginning to end.
Is this a known issue? I am happy to provide one of the MP3 files should anyone want to perform deep diagnostics.
Many thanks.
Do they have a particularly large album art attached to the files? Do you know the pixel size ofd the album art (mp3tag app will show you)
The cover image size is 295392 bytes.
(I am not sure about the pixels).
What is strange is that two files with the same image size (same image appears on other devices) from the same provider (Amazon), one of them haves the 4.7 second hiccup, and the other does not.
Below
  1. This one hiccups when played on the UnitiQuite
$ eyeD3 86_16\ -\ La\ Cumparsita.mp3
/path/86_16 - La Cumparsita.mp3 [ 8.93 MB ]
Time: 05:36 MPEG1, Layer III [ ~215 kb/s @ 44100 Hz - Stereo ]
ID3 v2.3:
title: La Cumparsita
artist: Los Reyes Del Tango
album: A Don Juan
album artist: Los Reyes Del Tango
recording date: 2005
eyed3.id3:WARNING: Non standard genre name: Latin Music
track: 16/16 genre: Latin Music (id None)
disc: 1/1
Comment: [Description: ] [Lang: eng]
Amazon.com Song ID: 201508849
FRONT_COVER Image: [Size: 295392 bytes] [Type: image/jpeg]
Description:
PRIV: [Data: 8207 bytes]
Owner Id: www.amazon.com
  1. This plays normally on the UnitiQuite
$ eyeD3 82_01\ -\ El\ Huracan.mp3
/path/82_01 - El Huracan.mp3 [ 7.25 MB ]
Time: 03:25 MPEG1, Layer III [ ~284 kb/s @ 44100 Hz - Stereo ]
ID3 v2.3:
title: El Huracán
album: A Don Juan
track: 1/16 genre: Latin Music (id None)
disc: 1/1
Amazon.com Song ID: 201508834
Description:
If your UnitiQute 1 has the 2D streaming board (which I expect) and not the 3D streaming board (you can look at “about” in the app to check) then you shouldn’t have it on 4.9 firmware as it’s not compatible.
Whether you can recover the situation by reinstalling 4.8 I am not sure, but that’s probably what I would try.
Thanks for your suggestion. I don’t know much about 2D versus 3D boards. Maybe you can help me determine exactly what is in my UnitiQute box?
Here is the product information from my Uniti
Product: UnitiQute
IP Address: 192.168.16.X
App: 7.4.1
App Build: 1154500
ARM APP: 4.9.40
ARM BSL: 4.1.0
3D APP: 4301
3D BSL: 2559
3D CNE: 4301
MAC: 00:11:F6:XX:XX:XX
Device: samsung SM-G955F
Android: 9
Thanks.
Well that one has the 3D card as you can see from the line entries saying 3D on them. So it must have had an upgrade at some stage. That’s very good news!
Having said that, apart from that you are fine on 4.9 firmware, I don’t know why you have a problem playing your MP3s.
