Hi, my unitiqute logo lights up when first turned on, but when the screen comes on the naim logo light goes off, any ideas what could be the cause?
I’ve never owned a Unitiqute but could you have possibly changed the logo display settings when adjusting something else?
Thank you for your reply, the logo is now on permanently, do not know what was the reason, just turned it off and on again.
Could you have accidentally muted it? Or are you saying when you power cycled it the logo is now illuminated regardless if the unit is muted?
My UQ1’s logo goes off if I mute, lights up when unmuted.
The logo is actually a button that puts the unit in/out of mute, and if you keep hold the vol goes up or down.
It’s actually the only way I mute the unit, but could not be obvious if you don’t know, good point!
