hello everyone … I have a unitiqute 1 series … wired cat 6 … I happen to have double and even quadruple tracks in some albums … any of you have had the same problem ???
thanks
Where are the tracks coming from? A NAS? A USB stick? Tidal?
from a nas…in the nas they are ok…the pc reads them ok … before I used a Musaic mpl player … it read ok … only the naim app gives me this problem
I tried to re-install some albums in the nas … but after some time the problem returns
All the app does is show what the server software is sending. Can you install Asset on your nas? It’s good software and works really well.
Have you cleared the trash folder from the Nas?
What software is on the NAS to serve the tracks up to your streamer? (Something like Asset that HH mentions.)
ok … soon i will try with asset … i have a WD mycloud nas western digital …
thankss
thankss
Not sure whether you’ll be able to run Asset on that NAS. Might need to run it on a PC or something.
