UnitiServe and Adobe Flash
Hello All,
This maybe of use to some of you. With the demise of adobe dropping flash back in 2020 and the workaround, which for me stopped working on my Mac browsers a couple of years later, I think I have finally found away round this conundrum, well for Mac Users anyrate.
I’ve finally managed to download Adobe Flashplayer 32.0 and after some further research found that a browser called ‘Pale Moon’ still works with flash.
Installed Flash first and then the browser software.
I’m not affiliated to any of these websites and you download and install at your own risk.
Steve
You can still access the web interface on regular browsers such as Safari using this workaround:
Good Morning ChrisSU,
Unfortunately that workaround for me does not work anymore. If you or someone could point me to the link you described, I would be happy to give it another go. The link you posted now goes to an End Of Life page with no download.
I think Adobe may have removed this from their web page, probably for seccurity reasons. Not sure if it will work, but try this:
https://www.dropbox.com/scl/fo/bp1z6ud9mfhd4i2hxdx08/AGMtKrQxPf4DuwnFtZMcz1k?rlkey=b75yyqjcic5bk5g6bmbhizxu2&dl=0
Morning ChrisSU,
Thank you for your help it’s much appreciated. Nope it still does not work for me. On my Mac with the very latest OS version on it, I get a blank screen. For Mac users on this forum trying to view US on a browser, I genuinely think it’s broke…not surprised really. I don’t know whether anyone else can confirm this at all please?
Steve
Install chrome and use an extension to run flash
Morning Garyi,
Thank you for your advice. I have tried this many times with different extensions with chrome and either got nothing or just the NAIM logo as shown. I have spent a number of years investigating this, hence the reason of my initial post, but please, please prove me wrong.
Steve
It’s been a long time since I had my ns02. However if the logo is loading that would to my mind indicate a problem with your device not flash per say.
Hello garyi,
Absolutely no problem with my US whatsoever….famous last words. Use it everyday and broadcasts ok. As you can see in my initial post I can see the menu. The post was hoping to help people out who cannot use the flash interface via Mac. This is all to do with flash or rather the no support for it anymore.
Steve
I was scouring the web for what I used to use, but cannot find it.
Sadly the unitiserve was somewhat obsolete when it was released and in compute terms requires a necromant to function now.
I did not know I am a necromant. My US functions flawlessly without any issues. I can control it via the app (Android) or Windows. And I am not an IT expert.
BTW, it sound great.
