After my last laptop gave up the ghost I of course replaced it, I was then left with the task of replacing faved info, apps etc., herein lies the problem! On attempting to load the UnitiServe app from Naim I met with no success.
It would appear that now Naim has moved onto the Core that I am now ancient history in being a UnitiServe devotee! Of course being somewhat of a ‘luddite’ I expect a simple solution to my issue!
You can use the Naim Windows Desktop Client. You should have it on the CD that you did the last firmware update of your Unitiserve with. There was another thread about this yesterday with more info in it.
