If I remember correctly, the US doesn’t stream. You have to use it with a DAC. Is this correct? Do you use a streamer, streamer amp or DAC to play music stored on the US?
Thanks for the links . If you have a minute perhaps you would just walk me through the main steps you took to set up your backup ? I’m struggling a bit with all this .
