I noticed that by turning off the Unitiserve with the hand on the logo, this last one, once switched off, makes the Cisco Catalyst 2960 light orange until it is switched off with the rear switch. Who knows what it means …
probably the cisco is sad loosing the serve. Happy =green. Sad=orange. Dead= no lights
Which LEDare you referring to ? The port LEDs, or the system LEDs on the side of the switch… they all have specific meanings.
To the led where unit is connected unitiserve
What do the colors mean?
Solid Amber on the switch port LEDs, means the switch has blocked the port
