Anybody has the same problem with UnitiStar? Since I started ripping CDs, the discs were always ejected automatically once the ripping process completed.
All of a sudden, discs are not ejected automatically any more. I explicitely have to do this via the remote control or app. Any ideas?
Thanks, Christian
Turn the Star off, disconnect it from the mains, wait say one minute and then turn the mains back on. Likely when the Star has restarted you will find it works as it should.
Best
Once had a CD no wanting to come out of my Star. Did the power down restart and came out instantly and worked fine after that. So with @davidhendon on this one.
