I currently have an XS2 paired with a NAP200 and BlueSound streamer.
Would the Unity Atom be a step up in sound?
No.
XS2 with 200 is clearly better vs Atom .
The streamer dac of the Atom is better vs the Bluesound, but it doesn’t compensate enough the previous difference.
IMHO
You seem to be running 2 threads.
Xref here What's my Next Upgrade?
From xs2 and power amp combo, it would be 202 or better 282. The 200 can power them . Then add hicap.
Definitely not an atom unless you want to simplify to 1 box and downgrade at the same time.
