I’d like to temporarily use my Unity Star as a pre amp for a Nap300. I eventually intend to move to a dedicated streamer and preamp once the funds allow.
Can anyone advise on the cable needed to connect the Star to a NAP300 as the Nap appears to split the left and right into two separate din inputs? Perhaps this is not even possible?
You need a Y lead: 4 pin din to two XLR. Your dealer may be able to make it from the two leads supplied with the 300, or you could get one from Flashback Sales. Look for them online. Or, if you have decent soldering skills you could do it yourself.
