I’m facing a issue with my Unity Star streamer. Yesterday I’ve connect it to my router using a wired connection. At first it worked fine but after a couple of hours it just stopped playing.
I’ve tried just about everything to get it back working (different cable, different port, reset the Star, power cycle the lot) but nothing worked.
It’s fine using WiFi.
Anyone any idea what may be the issue?
As my Uniti Star is wired (and has been since I got it) and I have no problems, the most likely suspect is the router.
