Unknown connection error with iRadio
I have attempted to search answers before creating this; apologies if it’s duplication!
I have updated firmware on my NAC N272 to the latest
4.9. When I try play my iRadio pre-sets it endlessly tries and then fails to reconnect. Might this be a router setting issue? Are there recommended Router settings or parameters to avoid conflicting with Naim settings?
Thankyou!
Have you deleted your old presets and then searched for the stations again, then resaving them?
As HH says, but as well as that, if you go to the “Now Playing” screen in the app, then you can tap on the cancel or stop trying to connect or similar link and then leave the Now Playing screen. Should all work then.
I deleted my presets on the main unit however and when I then go into iRadio I get the “cannot read server” error screen. I was wondering, therefore If it might be a router setting that I need to amend?
It may be worth turning the 272 off, rebooting the router and then turning the 272 on again. I don’t think there is a router setting as such.
I think it is just that your 272 is still trying to find the old server, which of course it doesn’t need and won’t let it connect anyway.
The 272 will have been restarted several times in the firmware updating. The point of going to the Now Playing screen in the app is that you should be able to stop the 272 trying to connect to the old server.
In an iPhone you get the Now Playing screen by going to iradio and tapping at the bottom of the screen.
