Updating Firmware and Software On A NDS
Hi.
I was reading through the instructions for updating to firmware version 4.9 and it says to check which version of firmware and software is currently installed.
I pressed the spanner symbol on the remote and went into factory settings. However I cannot find where it says “Firmware version” and where it says “Software version”.
How do I find the current firmware and software versions?
Thank you.
In the app.
Settings/about - Streamer version
Hi @Blackbird
Thank you for the information.
Among the instructions there is a page titled “Streaming Products” and there is one column headed “Type” and one headed “Update”.
Under update it says “Version 4.8” and under “Type it says software”, and then under update it says “Version 4.9” and under “Type” it says firmware.
Are software and firmware interchangeable terms?
After checking I am Version 4.6. Do I have to install versions 4.7 and 4.8 before version 4.9, or does version 4.9 also contain 4.7 and 4.8?
Thank you.
Firmware and software are often names used to talk about the same thing and in this case it is. If you’re on 4.6 you can go directly to 4.9.
"You’ve likely heard the terms “firmware” and “software” thrown around — sometimes interchangeably. While there’s a dramatic overlap between firmware and software in modern technology, there are still some differences between the two. Firmware is a type of low-level software often more closely linked to the functional hardware, while “software” as a term generally refers to things you can interact with, like an operating system or application.
The difference between the two is much less relevant than it once was, but here are some ways to think about each."
Hi @Blackbird
Thank you for all of this information.
If I go straight to version 4.9 will the updates contained in versions 4.7 and 4.8 also be donloaded into my NDS, or would I have install versions 4.7 and 4.8 separatley to benefit from the updates in those verions?
Thnak you.
4.9 is the complete package containing all software changes made to date.
4.9 is as Roberts says the complete package including the earlier updates.
Hi @Blackbird @robert_h
Thank you for your help.
