Updating Uniqute 2 w/out display
Hi All, I acquired a S/H Uniqute 2 last year. Now, of course I’d like to do the 4.9 firmware update. My question is - my Uniqute has no display (I’m sure it’s the connector cable as there’s a sharp bend in it which if I press the display sort of returns). Do I actually need the display for the update? Can I just start it and leave it for a couple of hours? :grimacing:. Update will be from a Macbook Air via USB C.
This recent reply from @NeilS re. updating a Unitilite with a dead display might help…
The update only takes about 15 minutes. So leave it for a minute or so after you get the green tick from the updater program before trying anything and you should be fine.
Thanks, my network is hardwired so don’t need to worry about WiFi
