Updating Uniti2 for the first time
Basically where do I start ? using 2013 model ( not Bluetooth) help appreciated, thank you
When you download the update to your computer, you will get the instructions with it on a .pdf file. Follow them to the letter! You will need a USB to mini-USB cable and you’ll have to download the driver for that.
Good luck!
Software updates can be found here:
If you aren’t sure, ask here! Also give each step plenty of time to complete. You don’t need to panic because something isn’t doing what you hoped (yet).
Best
thank you
Just been looking at the updates. do I need to the newest one or all of them ?
Newest one
thank you
