Is there an improvement in SQ by getting the pots on my 82 upgraded?
The amp was serviced by Darren at A class about a year ago.
It will depend on which POTS board your NAC82 currently has onboard. If earlier than POTS7 then yes, possibly worthwhile. Otherwise probably not.
Hi Richard…it was the original pots circa 1994 or so if memory serves correctly….
In that case, probably worthwhile. Perhaps best to have a chat with Darran. Normally these things are done at the same time as a service.
Good idea…will do.
Thank you.
