Upgrade advise
Hi all, I am currently consideraing for upgrading my systems with NAC 282 with NAC 122X, Presently NDX2, NAC 122X, NAP150X, Flatcar 2 with Neat Motive 2. not sure replacing the power amp to NDR 250? I would very much apreciate your expert opinionas.
A 282 can be powered by a flatcap but hicap is best, so add that to your budget.
Thanks Robert I will
282/Hicap/250 would be a good amp to aim for, but I would suggest that you would then benefit greatly from a source upgrade. Adding either a power supply or DAC upgrade to the NDX2 would bring it up to the level of the amp.
There are other alternatives in the Naim world depending on budget.
Eg just a supernait, or 202/200 (with a napsc for the 202). The 200 can power the 202, or your flatcap, but yet again 202/hicap is best.
Thanks Chris
