Superlumina DIN/XLR between Hicap DR and 250DR… that is where I would start… and stop.
I say this because to my ears it is the weaker component of a 282/HCDR/250DR system
others may disagree, but that’s my finding… there’s not much pointing spending more money until the weakest parts of the system are upgraded, as they form a bottle neck to the full system performance
While I did find improvements going from one HCDR to 2 HCDR’s & then again to a SCDR, personally I didn’t feel there was a massive difference between the 2 HCDR’s vs the SCDR, granted there was improvements from 1 HCDR to two so the jump would seem bigger if you are going from just one HCDR. If my plan was to stick with the 282, I don’t think that would be my first improvement. Personally I think the SL speaker cables were a larger change vs NACA5 then from 2 HCDR’s to SCDR.
From what I have heard from a short demo the 300DR does seem to smoothen out things vs the 250DR while on a 282, so not a bad option if you want to keep the 282.
But again, my vote would be for room treatments, likely go much further in sound improvement vs $ spent.
Bar speakers I am in the same place your are albeit with a Fraim so that would be my vote.
I do mull over the next upgrade, maybe a Supercap, then 252…
I am really tempted to wait for a 552 and do the job properly. Trouble is it could be a long wait, but the system doesn’t really lack anything and I might just stay put.
If you feel the same then it makes sense to get the maximum out of the existing system with Fram, cables etc.
Something that was not proposed yet, but smoothed so nicely the sound for me, quite night and day : adding the Etheregen switch with MCRU ps. A box upgrade !
How much energy/time have you put into the overall set up. If not really, I would first of all try and address your ‘ brightness’ issue. For starters I would try and ascertain whether your first reflection from your left speaker is on your glass doors? ( This could mean moving Left speaker slightly/ change the toe in or cover the glass with a light/ medium curtain)
Secondly I bet your left channel is playing ‘ louder’ than the right simply because your right channel is loosing its output into a much bigger space- ie the system is somewhat lob sided in its speaker set up. As a trial I would move the right speaker forming the same distance from the fire place as the left speaker, or in other words much reduced distance between the speakers. Hence swap the right speaker location and racks over.
I would then put an additional thick wool rug in front of the speakers to reduce a floor reflection between the listening position and the speakers. This could also help further reducing a secondary ceiling reflection.
Don’t start throwing money at the system until you have exhausted all your existing set up options. ATB Peter
Fair point on HCDR vs SC, I knew many plan was to go from 282 to 252 so for me and my journey was logical
On 300, my plan following number of demo was to move to 250DR, purchased sh 300, and then serviced and DR, my journey has ended with 300DR everything I ever wanted and more
As I said in my post there is no wrong, but depends on journey plan for OP
I see on the OP system pic a big window at the left on the speaker, and a big glass behind that same speaker ( behind the guitar).
It may easily explain some brightness and agressive sound.
Some work on that before spending money on upgrades is perhaps mandatory.
Hi @aristoweb my system is in my Bio - 252/SC/300DR with NDX & Kilmax LP12 as sources
over the 20 years of ownership I have used and experience of nearly all classic set up, hence my comments on your post - nothing is wrong but we all ideally like to get the most music for ££ spent
so condenced verison of my history would be
CD5i/202/200
CD5i/202/HCDR/200
CDX2/XPS/202/HCDR/200
NDX/202/HCDR/200
NDX/282/HCDR/200
NDX/282/HCDR/300
NDX/282/HCDR/300DR
NDX/282/SC/300DR
NDX/252/SC/300DR - only play NDX around 5% on IRADIO or FLAC, my main source is LP12
i have always worked with my dealer on upgrades before purchase and pleased to say following 20 years of ownership my jouney is about finished, love my system and the music which is brings - for me I am never going to be able to climb the highest of 500 system, in saying that 252/300 is 4 boxes of black musical magic
