Simplest is probably star pre out into supernait av input with av bypass switched on. Just use standard rca interconnects. Volume control is then via the star. Speaker cables always from the supernait regardless of the option selected, your star is a source only.
Thanks Robert, works perfectly! Thanks. Saves me from getting a special cable for this temporary solution.
