NDS arrived and installed. Condition is perfect as described and all original packaging, unused remote still sealed, but no rubber feet
Any ideas why they might have been removed?
Havenāt had a chance to listen yet
Not sure about the NDS, but I think all units with internal suspensions have metal feet, and as far as I can feel under my Superline they are the same as in your pic.
Ah ok thatās helpful thanks.
Thereās a hollow space within which means you can attach transparent bump-ons to a glass shelf that can then fit within the feet (important they donāt touch the feet though). That way thereās no chance of the unit accidentally being pushed or pulled off the shelf by children etcā¦
Great thanks both for clearing that up.
Itās sounds absolutely stunning by the way
PS the transit bolts were in when I turned it to take that pic!
