I think as it is a common -ve out of the hicap , even though the signal has passed through monoblocks I can connect the REL to the speakers. I just have to work out if I need to Siamese the negatives of the two S600 speakers or can I take just the -ve from 1 speaker. REL did not recommend doing this from monoblocks but suggested picking up the speaker outputs from a power amplifier rather than at the speaker end.
All a bit confusing…… Tom.
I’m running a REL sub into the back of my SN2 and it doesn’t seem to be causing any issues. Is there something I should be listening out for, in particular? I’m using designacable’s (much cheaper) version of REL’s bassline blue cable designed for Naim amps.
If you are using the Naim version of the Bassline Blue cable (Rel or Designacable version) it is specially modified to ensure compatibility with any Naim amp, so you should be fine.
Thanks Richard,
I ran + & - from each speaker terminal to a connection block, joining the -ve wires there and then terminal block to REL high level Neutrik connection & it works - acid test “Safe Word” serpentwithfeet with an ornament-rattling bass line.
Now ready for the 82 and hi-cap…… Tom
It so happens that the individual purchasing the second hand 552 combo has a 52/supercap combo, so the dealer put a trade together & I have jumped straight to my (hopefully) end position without going through the 82 twin hi-cap stage.
It should arrive in the next few days……
I’m well pleased as that should be well matched to an NDX2/ XPS2 front end. Sadly I have already purchased a second hand hi-cap that I was hoping to use with the NAC82. If it arrives before the 52 I can give it a test……
My LP12 NAS & Wadia CD have now gone to my son as it is some years since I spun any sort of disc on my home system, strictly Qobuz now, so system will be:
NDX2/XPS2>NAC52/Supercap>EAR509>Ovator S600
so other than playing around with cables I think that will be it
So the NAC52 & supercap arrived &, after much cursing, I have them installed in the system. Despite their age there has been a significant improvement, tighter bass, better separation and clarity, all in all a much more engaging listening experience.
I purchased from a dealer in Te Aro, it was a deal where the 52 owner wanted to purchase a 552 combo so I took the 52/supercap. I think I may have paid a bit over the odds, but the result is great.
The original owner had ordered a non-Naim burndy so I will keep a keen eye for when it arrives as there can’t be too many people in NZ looking as that cable is only suited to the 52.
Ah, I wondered what happen there with the 52 and 552, great buys all round. Those other options are worthwhile too, but can’t be discussed on the forum.
I have decided to get re-caps on my 52, Supercap & XPS2. As you may know, the long-term NZ agents lost their agency some time ago, but still have their re-cap guy; this means I don’t have to send the gear off-shore. Did I see in a recent post that you now have replacement POTS8 boards? If so would one be available for NZ?
As I’m getting the re-caps done, I calculate that I will be 86 before they need doing again, so probably their last outing….. Tom.
Tom, I do recall @NeilS posting that some POTS8 boards were available again. As for availability in NZ that’s something that your dealer or distributor would need to ask Naim about.
