Curious to know if anyone has done this upgrade with a 252 and what they made of it.
Anyone?
I have. I bought a 252 with Supercap and ran it for about six months in to a 250-2. I then had a 300 Serviced and DRâd. A Supercap DR came up and I swapped out the Supercap. The DR and 252 made a big difference with the 300DR.
Thanks Bruss thatâs encouraging.
Any other experiences upgrading a Supercap2 to Supercap DR?
I just got my 252 serviced and my Supercap serviced and DRâd. Putting it all back together tomorrow!
Ooohhh exciting let us now what you think
Stu
I found the change very worthwhile when I had the Scap upgraded for mine. Added a level of detail and insight. Bass resolution improved perhaps most. It is very much an all round change though not just one thing. Note the Scap2 wasnât overdue a service so a fair comparison. It was the first of my three PSâs to go DR and convinced me to get my others done.
Bruce
Well, hate to be the naysayer but, quite honestly, I donât hear much of a difference between the serviced/DRâd gear and my best recollection of it before it was serviced. Of course, on the one hand, itâs been almost 3 months since I sent the system of to be done, so my memory may be suspect. On the other hand, confirmation bias my explain any differences I think Iâm hearing (I must confess, I expected to hear a BIG difference with my 20 year old 252/SC).
Iâll let it all run in for a week or so and post back
Isnât there supposed to be quite a long âburn-inâ period after servicing? Particularly on the 252?
Hope it improves for you with time!
Well, a couple of weeks have gone by and Iâm not noticing any ânight and dayâ changes. Still sounds good but not the improvements others appear to be hearing with the service/DR upgrade.
