1700
One side of the LP12 mat sounds better than the other.
Again, I think you have to look at the actual cost and whether or not and how you want to upgrade which components in the future.
Class A normally give āservice invoicesā detailing the service, if you go for the Supercap ensure you have that paperwork. WIth a 2018 service date Iād imagine a very healthy resale cost if you decided there was little benefit over 2 HICAPs.
Excellent point @djh1697
I made that same call, the LP12 is now at the dealer for maintenance to make sure it will perform optimally within its current configuration, but for now thatās the end of the road.
There have been several posts and threads about the paradox of vinyl - how rewarding it can be but also the level of attention and dedication it requires for that reward. As with some others I often donāt have enough room for that anymore in my current life, whereas before it was a life style.
So, future plans and upgrades will go into a streaming source. This to replace the FM tuner we miss dearly with internet radio, to have access to the Spotify (lo-res) and Qobuz (lossless) catalogues, and to play from a (large) USB stick the complete CD collection we ripped some time ago.
Food for thought indeedā¦
Serviced in 2018 probably not bad at all compared to around Ā£5k for a new DR model - try to get a feel from somewhere like TomTom Audio what these āpre-lovedā items go for.
Bear in mind the 82/282 only uses a subset of the circuitry in the Supercap compared to a 52/252 but it opens the door to a 52 or 252 (with additional cables, unless this had a Burndy of some sort included).
No Burndy but will include a couple of SNAICS.
Out of interest are all Burndys the sameā¦I have a spare Burndy that came with the XPS2ā¦ Would that work with a SC and 52 for example?
A couple of SNAICs adds value too, I donāt think the Supercap came with any. The DR doesnāt.
Sadly Burndy cables are specific to certain categories of components so a Burndy for a NAC 252 would be different to one used with a current SNAXO.
Iām fairly sure someone linked to a list of Burndy types a few months ago, I canāt recall the thread.
If itās not in the current forum FAQ it would be a good addition.
If itās there already Iām going to feel daft.
The ideal situation would be if the vendor would allow you to try the Supercap first with a no quibble return policy if it wasnāt what you expected.
Would the vendor (if a reseller) allow trade-in on the HICAPs assuming theyād be surplus to requirements?
So as some of you may have gathered Iām airing towards the SC at the moment as its a) available, b) will improve SQ for both sources (hopefully) and c) the Karousel will be around for a while so there is no hurry and will probably sell one of my cameras to fund the Karousel/Trioka upgrade.
Its its a private seller I donāt think the trial is a goer!
A SuperCap will benefit your whole system - whatever the inputā¦
I canāt recall or find anything.
Yes, Iād like to do a Burndy ID thread but I only have an S-XPS and a NAC552 Burndy here to photograph.
No, they are all different - some may look similar but the pin layouts and number will be different.
A shame but ultimately probably understandable.
Iāve seen elsewhere:
Naim Burndy S-XPS 11 Pin Interconnect Cable - 1.25 Metre
The Naim Burndy 11 Pin is designed for connecting the XPS power supply to a CD Player.
This Burndy is compatible with Power Supplies: XPS, CDPS, XPS 2, 555 PS
CD Players: CDX, CDS 2, CDX 2, CDS3
Naim Burndy SNAXO / SuperLine 17 Pin Interconnect Cable - 1.25 Metre
The Naim Burndy 17 Pin is designed for connecting the SNAXO Electronic Crossovers or SuperLine Phono Stage to a SuperCap Power Supply.
NAP 300DR
Supplied with 300PS, Burndy
NAC 252
Not sure but canāt see that has its own Burndy supplied.
Presumably others too.
Also:
NAC 52
Does that come with the 52? Not sure if it differs from the 252 one.
Naim CDSPS to CDS
Naim CDSPS to CDS2
I have one of these. Again not sure if it differs from an XPS to CDS2 one. At the time I think I was told I needed a special order one.
Surely Naim has all this written down somewhere?
Ideally thereād be an easy to reference Burndy guide for consumers and dealers otherwise people risk a very expensive purchase only to find they are missing an essential Ā£500+ āinterconectā.
So the Super cap arrived todayā¦ā¦just warming through before I hook it up tomorrowā¦.will let you know what happens.
Been having some more thoughts on the refurb Troika.
What are peoples thoughts. Better than the DV 20X 2? Much of an improvement?
Iāve had both the DV 20x2L and a Goldring-rebuilt Troika ā my feeling is that they have different strengths, rather than one being unequivocally better than the other.
Compared directly on my LP12/ARO, the DV was big, warm, and bouncy; the Troika was definitely more detailed and neutral, but also smaller-sounding. Going from the DV to the Troika was rather like looking through binoculars and then sharpening up the focus, if that makes sense.
Bottom line: the DV was more fun, the Troika more hi-fi ā so it really depends on your mood and preferences!
Just found it again - not a link but an image:
