Last December I upgraded my tone arm to a tiger paw javelin. My dealer has a used superline available and I’m thinking of taking the plunge. I currently have a prefix being run with a supercap (non dr). Can I expect improvements over the prefix if going to the superline? Turntable is an LP 12 with a linn Krystal cartridge and lingo 2 power supply. Thank you!
Yes but use the Burndy don’t try and get away with a Snaic.
The prefix is a close coupled stage line…
The superline is all together on another level…
No more to say really…
If you already have a SC then a pre-loved Superline makes perfect sense. Big step up from a Prefix
“If you already have a SC then a pre-loved Superline makes perfect sense. Big step up from a Prefix”
I agree and definitely worth a demo in your system.
Richard
With the right loading plug for your cartridge will be superb.
Lindsay
Which sub-chassis?
