Upgrade to uniti 2
Any ideas how to upgrade uniti 2 please .
If you go to the product web page, you can download the update to a computer from there. Follow the instructions to the letter and you should be OK. What version are you on now?
Thank you , I will give it a go , I think I’m on the previous version. Also is it worth adding a power amp?
The current version is 4.6, and the last was 4.4 so you should be OK. Remember that you will need a mini-USB to USB cable to connect to a computer, and on that computer, you need to download a suitable driver, just open the instructions that are included with the download and follow them to the letter. It can seen a little daunting when you do it for the first time, but once you’ve figured it out it’s pretty simple.
The current version is 4.7…
Quite right, David, I realised as soon as I hit the button! The 4.7 update can be found here:
but not on the product web page, which still shows 4.6 as the latest.
Thank you , I will give this a shot next weekend .
