UPnP problem
I’m not sure whether this is the right place to ask but anyway… my Nova has just decided to stop seeing an external hard drive. It’s a cable connection via my router and PowerLine and has worked perfectly up until now. I have no problem accessing Tidal or internet radio plus the drive works fine can be accessed via my iMac. I’ve done the ‘unplug everything/turn it off turn it on’ stuff but still no sign of the drive. Any ideas?
Have you connected the drive directly to the Nova?
This might be better in the Streaming Forum.
Just so I’m clear - is this an NAS or just a USB hard drive? And what server software do you use? Do you have the problem using the Naim App? iOS or Android?
